Go Back  R/C Tech Forums > General Forums > Rookie Zone
Motor Type Against Gear Ratio >
Old 06-20-2002, 09:51 AM
CSA
CSA's Avatar
Please advise the suitable gear ratio range for 10T, 11T and 12T Motors. Thanks in advance.
CSA is offline
Old 06-22-2002, 09:41 PM
CSA
CSA's Avatar
Dear all,
Maybe I posted a silly question before. In fact, my problem is how to select an appropriate combination of spur gear, pinion gear and Motor Type, in order to achieve a particular gear ratio. For a rookie, any suggestion?
CSA is offline
Old 06-23-2002, 08:59 PM
ijnek's Avatar
Smile
there's no particular good gear ratio...
u will jus need 2 trial and error for a suitable gearing.
low gear ratio=low top speed but slow acceleration
high gear ratio=high acceleration but low top speed...
this is 1 of the guide line tat u can keep in mind...
but for those hot and fast motor especially,u should always try 2 keep ur gear ratio high so tat it wun heat up so fast...
always check ur motor temperature after a gear change 2 c if it's suitable for tat particular motor...
ijnek is offline
