Tamiya TT-01E question
Hia all...
Ive gota tamiya TT-01, abit basic I know.
Firstly I replaced the stock motor with a 15T motor and it went pretty well so I decided to uprate the gearing to a 25t pinion and 55t spur gear set from the tamiya hop-up range and its running so much slower. Umm thought it would be better???
Only other things ive done is the bearings and the alloy main shaft. So much quieter.
Suggestions please. From a newbie
Hi, that's an FDR of 5.72. For 15T probably FDR of 7 would be a good starting point.
22 pinion / 61 spur
22 pinion / 61 spur
Oh I thought the higher the pinion number the better??
The stock spur was 61t now is 55t.
Do I need to upgrade the esc??
The stock pinion was 19t
So am i better going back to 19t on the pinion rather than 25t??
Ive ordered a 15turn supported ESC too
Any ideas fokes!?
55/19 will not mesh. 61/19 might be undergeared. Try 61/22.
