Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 01-06-2005, 01:50 PM   #1
Ridge_Racer's Avatar
Send a message via MSN to Ridge_Racer Send a message via Yahoo to Ridge_Racer
Default basic motor maintinance
hi all
I have a Team 1 stock motor in my TC3. lets say Ive run it about a dozen times. What should I be doing to keep it running smooth.
thanks
Ridge_Racer is offline   Reply With Quote
Old 01-06-2005, 01:52 PM   #2
Sorry, Double post. Mod God please delete me
Old 01-12-2005, 02:18 AM   #3
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default Re: basic motor maintinance
Originally posted by Ridge_Racer
hi all
thanks
It depends on how competitive you want to be. I would recommend cutting the comm atleast every 3 runs lightly and serrate the brushes the same time and also clean the inside of the motor with a motor spray/brake cleaner and polish the armature shaft with 2000 grit sand paper and finish with a metal polisher and re-oil the both bushings every run.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 01-13-2005, 03:49 PM   #4
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
After a dozen runs on a stock motor I'd assume your brushes are pretty badly burnt and your somm is pretty scored. The com does need to be turned every few runs, even in stock. Brushes, as long as they're not too discolored or pitted, clean them up and run them until they're showing some discoloration. They're done after that. The more often you cut the comm, the better your motor will run and the longer it will last. If you go too many runs and scorch it, you'll have to cut too much off it to get it true and this will shorten the life.
Jon Kerr is offline   Reply With Quote
Old 01-13-2005, 11:00 PM   #5
Is there anyone here at trackside can help me with my motor? I don't want to run it to the ground but I don't have the money to buy the tools that are needed to tune it. (it may be too late already)
help
http://www.countdowntovegas.blogspot.com
F/S: Lehner Basic XL3100 motor SunnyHouTX R/C Items: For Sale/Trade 1 08-29-2008 10:00 PM
WTT Lehner Basic motor hardrider R/C Items: For Sale/Trade 0 05-23-2007 07:43 PM
Basic motor info tc3team Rookie Zone 4 01-17-2007 03:24 AM
Basic needs. warrenf Rookie Zone 13 01-15-2006 02:08 PM
basic motor maintinance Ridge_Racer Rookie Zone 6 01-08-2005 07:41 PM
