Power Supply
i was wondering the same thing
ttt
ttt
huh
Why would you want to do that? Couldn't you just keep them apart and it would do the same exact thing? I wouldn't even bother. Also, wouldn't you want to connect them in seris so that they will come together? Like I said, I wouldn't try it.
I woldnt do it - if they aint EXCATLY equal, strange things can happen...
Why would you do it?
I don't think it would work because the first power supply would only output a max of 14 amps to the second power supply so the second power supply would only get an input of 14 amps from the first power supply. At least that is what I think.
Re: Power Supply
Originally posted by KoE
can i hook up my 2 14amp ps parallel? will the combined units capable of juicing out 28amp that way
