Go Back  R/C Tech Forums > General Forums > Rookie Zone
Tamiya TT-01E question >
Old 01-25-2012, 04:12 PM
Default Tamiya TT-01E question
Hia all...
Ive gota tamiya TT-01, abit basic I know.
Firstly I replaced the stock motor with a 15T motor and it went pretty well so I decided to uprate the gearing to a 25t pinion and 55t spur gear set from the tamiya hop-up range and its running so much slower. Umm thought it would be better???
Only other things ive done is the bearings and the alloy main shaft. So much quieter.
Suggestions please. From a newbie
Mick.borthwick is offline
Old 01-26-2012, 02:23 AM
SolderGlob's Avatar
What were the stock gears? 25/55 might be too high and you may need to go with a smaller pinion.
SolderGlob is offline
Old 01-26-2012, 03:32 AM
Hi, that's an FDR of 5.72. For 15T probably FDR of 7 would be a good starting point.
22 pinion / 61 spur
rccartips is offline
Old 01-26-2012, 08:06 AM
Oh I thought the higher the pinion number the better??
The stock spur was 61t now is 55t.
Do I need to upgrade the esc??
Old 01-26-2012, 08:33 AM
The stock pinion was 19t
Old 01-26-2012, 11:26 AM
SolderGlob's Avatar
Higher is not better if your motor cant keep up. As a general rule with gear changes, only go up or down 1-2 teeth at a time.
Old 01-26-2012, 01:52 PM
So am i better going back to 19t on the pinion rather than 25t??
Ive ordered a 15turn supported ESC too
Old 01-27-2012, 03:32 PM
Any ideas fokes!?
Old 01-31-2012, 05:17 PM
55/19 will not mesh. 61/19 might be undergeared. Try 61/22.
