Go Back  R/C Tech Forums > General Forums > Rookie Zone
need hlp plz hpi bullett >
Old 01-07-2012, 08:04 PM
Default need hlp plz hpi bullett
hi guys,needs some help. got a hpi bullett 3.0 nitro st,had if for say 6wks,ive recently broke it in / tuned it got it cracking!!!! i havnt used it for couple of weeks say and i went to use it yesterday and when i start it, is revving its head off and wont stop i can apply the brakes and it stops then it revvs high again all on its own,whem\n applying the throttle on the hand controller it does nothing plz help cheers confused
bullett is offline
Old 01-07-2012, 08:36 PM
Just a guess from another newbie, but did you turn on the car before the radio?
karpouzian is offline
Old 01-07-2012, 08:46 PM
Miniyota's Avatar
^ +1
Turn on the electronics and reset the throttle servo to the neutral position on the remote - then start the motor
Either your getting interference or your throttle position is not set correctly, either on the remote or the actual linkage in the car
Simple solutions, might be more to it but this is where i would start.
Miniyota is offline
Old 01-07-2012, 08:53 PM
yeah i always turn radio on first off last
bullett is offline
Old 01-07-2012, 08:57 PM
Originally Posted by Miniyota View Post
^ +1
will do cheers mate,they were all facing up on all channels 1.2.3!!!! which one is the throttle? channel 1...... just that when it started the wheels are going flat chat when all facing up.ill wait till the glow igniter is charged and ill giv it ago.thanks
bullett is offline
Old 01-08-2012, 12:52 PM
will the throttle shold be channel two. I hope you charged your battery in the car and the tx if need before running it again after 6 week if the battery and the tx or the car are dead or to weak for the rx your servo might not be getting enough juice to work right which will or can cause like iterfercne issue.
imrob is offline
Old 01-08-2012, 01:15 PM
hotrod87's Avatar
Trader Rating: 252 (100%+)
1 to turn 2 to burn. You might check the throttle linkage and make sure it didn't come loose I've seen it happen. The throttle valvein the Carb can rotate while the linkage just sits there.
hotrod87 is offline
