Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 12-21-2004, 09:40 AM   #1
Default Measuring Amp Draw
How to measure amp draw of a 9t motor?
RC12L3a is offline   Reply With Quote
Old 12-21-2004, 06:25 PM   #2
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
A dyno, I'm sure there's other ways... I just dont know them.
Nrctc3 is offline   Reply With Quote
Old 12-21-2004, 07:45 PM   #3
bst
Default D.C. AMP/VOLT METER
CHECK YOUR LOCAL RADIO SHACK FOR A D.C. VOLT/AMP METER. NOW WHAT TO DO WITH THE INFORMATION? OR WHAT DOES IT MEAN? I DON'T KNOW, BUT WOULD LIKE TO FIND OUT. PLEASE PASS ON ANY INFORMATION. THANKS, DON
bst is offline   Reply With Quote
Old 12-22-2004, 11:52 AM   #4
factoryteamryan's Avatar
R/C Tech Charter Subscriber
factoryteamryan is offline   Reply With Quote
Old 12-28-2004, 03:47 PM   #5
Regional Moderator
there are meters capable of measuring amp draw by measuring the magnetic field around the wires. the Fluke version is at this url
http://us.fluke.com/usen/products/Fl...keUnitedStates
petzl is offline   Reply With Quote
Old 01-02-2005, 10:51 AM   #6
Registered User
You need either an inductive style amp meter like shown above with the Fluke model, or a inline amp meter.
Inductive meters use a magnetic field to count the number of electrons (or protons, depending on the theory used.) moving through the wire.
Inline meters measure the amount of current flowing through them.
Many multimeters have an inline amp meter function - but - they only typically measure 5 or 10A max. You'll need to find a amp meter that can tolerate higher amps, which is also found on something like the Fluke meter.
Desolas is offline   Reply With Quote
Old 01-10-2005, 06:44 PM   #7
schmelme's Avatar
The best way to measure amp draw is with a charger or power supply capable or running the motor at 3 volts or so. Checking amp draw is good way to check the condition of the motor after some runs with it.
schmelme is offline   Reply With Quote
measuring amps and how big is 2 big?? Reburg99 Monster Trucks 1 03-07-2007 07:17 PM
Measuring droop peded Electric On-Road 5 01-19-2007 08:02 AM
Measuring armatures John Doucakis Electric On-Road 4 12-16-2003 09:11 AM
Measuring Amp draw by a discharger, HELP! Cain Electric On-Road 5 09-04-2002 01:36 PM
