Go Back  R/C Tech Forums > General Forums > Rookie Zone
Lipo Battery run time? >
Old 09-19-2011, 10:01 PM
wrathfull's Avatar
Default Lipo Battery run time?
So I fairly new to Lipo batteries, I have done a bunch of reading but can't figure something out. I was told not to run it completely down because it can damage the battery. ok, so then how do i know how long i can run it for? Running it down till i notice a loss of power i can notice, but I am worried about my 11 year old son noticing that when he is having fun. I have a rustler vxl that has stock electronics, and just bought a used sc10 for my son. The sc10 has a Orca vrita vtc pro esc. My thought is don't esc's have a option to shut the car down if the battery usage reaches a certain point, like i am assuming running it down to 20% would be safe?
Can anyone answer this for me plz? thanks in advance
ps. the only lipo battery i have atm is a nuclear power 7.4v 5000mah 25c
wrathfull is offline
Old 09-19-2011, 10:59 PM
some esc have a cut off features on it, mostly brushless type esc.
it will start to cut the power off when its in low voltage then it will die before u finish the battery.
u cant run the lipo all the way till empty otherwise it will damage the cells then it will get fat, lol. once it gets fat theres a chance of it blowing up or caught fire.
cielo1889 is offline
Old 09-19-2011, 11:09 PM
ta04evah's Avatar
If your current speed control doesn't have a lipo cut off function then you can use one of these. http://www.hobbyking.com/hobbyking/s...dProduct=18987
The volume of the alarm is very loud and very noticeable even above the sound that the truck makes when running, it even has led's that turn from green to red when the alarm sounds.
Cheers
Rob.
ta04evah is offline
Old 09-20-2011, 12:05 AM
wrathfull's Avatar
yes it looks like both the ESC's i use have low voltage detection so thats great, thanks for the help guys.
Old 09-20-2011, 12:12 AM
TOM MAR's Avatar
TOM MAR is offline
Old 09-22-2011, 08:29 PM
Chad Smith's Avatar
Lipos offer alot more run time than any other battery.
Chad Smith is offline
Old 09-22-2011, 09:27 PM
mjc597's Avatar
Trader Rating: 29 (100%+)
yeah they do, i went from a 3000mah 7 cell nimh pack in my sons traxxas monster mutt truck, to a 5000mah 2s 20c lipo...holy crap, it runs strong for 25 minutes bfor the lvc kicks in!!
mjc597 is offline
Old 09-24-2011, 07:20 PM
rdl77's Avatar
Trader Rating: 27 (100%+)
Cheers
Rob.
will this work on my stock inferno ve set up, running 4s(2 2s in series) since the balancer plug only have 3 wires per battery. i dont want to run my lipo's to 3v per cell(stock esc cut off), the alarm from hk sounds at 3.3v/cell. Or do i need 2 alarm, 1 for each pack. thanks
rdl77 is offline
Old 09-24-2011, 09:06 PM
ta04evah's Avatar
It may be a good idea to get 2 of them and have 1 on each pack, as one pack may discharge more then the other while running in the car.
For the small price it's a worthwhile purchase to help protect your batteries.
Cheers
Rob.
ta04evah is offline
