Broken horn
are you talking about the splined hub sticking out of the servo that the horn bolts to?
the horn is the arm that bolts to the servo, if you broke the part that sticks out of the servo (that the horn bolts to) then you might be able to replace it, you'll need to check and see if traxxas sells spare servo parts. (i've never had a traxxas servo).most higher end servos are rebuildable.
personally i'd just replace it with something better.
Super Moderator
Trader Rating: 31 (100%+)
You will need a new gear set for your servo, you normally can't just buy the main gear which is the one you stripped. I would also buy a new servo saver/servo horn as it's probably suspect at this point as well....
