New to RC, Need help!
Hello,
I just recived a OFNA Ultra GTP 1/8 scale .21 nitro powered rtr racer from my father who just remebered that it was sitting up in the closet. It has the .25 OFNA pull start engine in it and has never ran. Everything seemed to be put togther since there was not many pieces left in the box. I did some minor replacements like the support beams to hold up the body which were in bad shape. I aslo cut out the body(Viper) to fit over top. The only thing i found it needs is a new air filter, which i have located. The problem is i dont even know how to run it. I've heard they are pretty complex to start and i dont know the steps. So i was wondering if anybody could hlep me with that. It is also 4 wheel drive if that changes anything.
thank you,
SRQ_Racer
thank you,
SRQ_Racer
I'm not much help but here's something.
http://www.ofna.com/manuals.php
That should link to the manual for your truck. On the right side you will see two manuals, one for RTR (ready to run) and one for MBX (no idea?) I"m an electric guy but that's the first item I would read over before running the new toy.
Enjoy
Enjoy
link helps alot thanks
One more quesion if anybody can help me,
If i have a pull start engine do i still need a starter box?
Pull start engines do not require a starter box.
