Go Back  R/C Tech Forums > General Forums > Rookie Zone
Does TT-01 has a potential? >
Like Tree1Likes
Old 07-11-2005, 09:11 PM
  #286
A Ilievski's Avatar
Trader Rating: 39 (100%+)
what do you think of the new tt-01r
well i think its a awsome car its got the same features as the tb-02
its got fulll ball bearings
adjustable upper arms
choice of 2 rear toe in up rights
oil shocks
you can adjust the ride height
come with 3 spurs the 61,58,55
3 part tie rod set
evo4 style aluminum shaft
the price of it is gona be 213 usd with all that said the tt-01 r is gona be a awsome car to have
A Ilievski is offline
Old 07-11-2005, 11:03 PM
  #287
213 USD for a TT01-R?!
I would rather get a TB02. TB02 has all the stuff the TT01-R does, and more... and it's 2/3 the price of a TT-01R.
I'd only buy a TT01-R if it included a one-way and/or ball diffs.
Even then the TB02 would be the better buy.
They better lower the price on the TT01-R.
oil shocks
3 part tie rod set
dugrant153 is offline
Old 07-11-2005, 11:27 PM
  #288
Thai3g_Eclipse's Avatar
Where are you looking at? Tower Hobbies is going to sell it for $140 USD.
Thai3g_Eclipse is offline
Old 07-12-2005, 01:47 AM
  #289
rayman's Avatar
TT01R??
I'd rather get a ta05, tbo2 2nd and tao4 third.
My 3D Gallery Website
rayman is offline
Old 07-12-2005, 01:53 AM
  #290
A Ilievski's Avatar
oh ok i saw the price on the tamiua usa site but its still ok tho. has anyone here had a go with the ta-05 yet if so how does i go?
Old 07-12-2005, 02:13 AM
  #291
seen a thread or two about them.
Would like to definitely try it out...
But I guess taking it down with my TT01.. that'll be fun!! mwa ha haha
unless the TA05 kicks my butt...
let's hope not!
as for the TT-01R at 140USD... that's the price of a TB02 up here in Canada. I'd still get the TB02 at that price point.
Old 07-12-2005, 02:30 AM
  #292
rayman's Avatar
let's hope not!
you can try to take it out but only if it has a lousy driver.
same skilled driver he'll take u down with his ta05
But it does look cool with that tbevo4 blue propeller shaft. Too bad they didn't change the plastic to something harder like other kits. If they changed the suspension arms to the same design as tao4,tbo2 I have no doubt it will be just as good as those.
rayman is offline
Old 07-13-2005, 06:27 AM
  #293
rayman's Avatar
Look at the price of the tao5 in japan. Its 16800 yen roughly 170 usd
rayman is offline
Old 07-13-2005, 09:41 AM
  #294
that's about standard price. that's the price the TB02 started at
By the way, I added a large capacitor (4700uF 35V) to my TT01 and the Tamiya ESC. Gonna take it for a run today to see how it runs!
Old 07-14-2005, 01:38 AM
  #295
Quick question guys:
I'm planning to run in GT2 for TCS (wootz! Hopefully I can make it on time!)
However, I am running a black can, but am unsure of whether I should use the plastic or aluminum center driveshaft.
The plastic driveshaft is WAY lighter... so was wondering if maybe it would be okay with the black can sport tuned?
Old 07-14-2005, 02:21 AM
  #296
danjoy25's Avatar
Trader Rating: 38 (100%+)
Now that the Tamiya moulded inserts are discontinued, anyone knows of any other inserts that might work with the Type A or B using stock TT-01 wheels.
danjoy25 is offline
Old 07-14-2005, 08:14 AM
  #297
rayman's Avatar
dugrant153 - The alum prop shaft is light and stiff. With the plastic shaft you'll just loose power when it flexes. For black cans you need all that punch and a one way is also needed to carry more speed on corners so you wont waste power from drag break effect.
danjoy25 - tamiya still makes 24mm shaped insert I think. Maybe you mean the 26mm insert which is not really recommended for electric touring cars. Time for a change, 24mm tires are the norm.
rayman is offline
Old 07-14-2005, 03:19 PM
  #298
danjoy25's Avatar
I do prefer 24 mm but it is for TCS stock racing, so I have to use tt-01 spec tires with only Type A or B rubbers. Can anyone suggest any moulded insert that might work or would the foam inserts do?
danjoy25 is offline
Old 07-14-2005, 07:08 PM
  #299
rayman's Avatar
Ah for TCS. If you look at the tao5 pic attachment it has from left to right, medium narrow slick tire, medium narrow fiber molded Type A,B3 tires and shaped inserts soft, hard. I remember using Type A and B and they were already 24mm so those shaped insert for the tao5 should work. Most tamiya kits have 24mm now. Unless its different for other TT01 kits.
rayman is offline
Old 07-14-2005, 11:17 PM
  #300
The Tamiya TT01 kit, as far as I know, comes with 26mm tires and rims. Or atleast, my kit did. 24mm comes with the more "intermeditate kits" and up (TB02, etc.)
I'll be using Type A's this Sunday :P (borrowed). If there is a rally class, I'll be running semi-slicks.
