Go Back  R/C Tech Forums > General Forums > Rookie Zone
Does TT-01 has a potential? >
Like Tree1Likes
Old 06-27-2005, 11:35 PM
  #181
Thai3g_Eclipse's Avatar
I think any ESC nowadays can take a stock motor, but being a cheap ESC I doubt it'll have very good constant forwarding amp.
Thai3g_Eclipse is offline
Old 06-28-2005, 12:15 AM
  #182
I'm running the Tamiya TEU101BK ESC with a Team Orion Core stock.
I bought a heatsink for ESCs and pasted it on the metal part of the ESC. It still runs pretty hot with it, though... hmm...
actually, I'm having a heat problem with my motor. I realize that the heatsink that I have covers the side vents of the can. Is that causing my massive overheating?
dugrant153 is offline
Old 06-28-2005, 02:01 AM
  #183
rayman's Avatar
To calculate stuff Im poor at math go here
http://www.gearchart.com/
rayman is offline
Old 06-28-2005, 02:09 AM
  #184
A Ilievski's Avatar
Trader Rating: 39 (100%+)
hey um the tamiya esc i dont think an handle a stock motor that good.
also i put that esc in my Mi2 untill i can buy a better one and when the car and every is turned on i dont even accelerate and the car twicthes up and down like it moves forward etc hoe can i fix this problem
A Ilievski is offline
Old 06-28-2005, 02:36 AM
  #185
tantalus007's Avatar
Trader Rating: 17 (100%+)
Rays_tt:
final drive ratio = (spur gear / pinion) reduction ratio
reduction ratio = specified in r/c manual (i.e. 2.353 for YOKOMO CGM)
I wouldn’t recommend on using the TEU-101bk when running a 27turn, 24-degree stock motor. I’d recommend you replace your esc with a novak xrs or futaba mc330cr because you might fry what you presently have. You’ll be experiencing dugrant153’s problem, esc tends to get pretty hot. Try the tamiya black (sports tuned) motor can first. You’ll be fine using that motor with your TEU-101bk esc.
Dugrant153:
How long do you run your TT01 on your tracks? Do you run it in excess of 5 mins?
Cheers!
tantalus007 is offline
Old 06-28-2005, 02:40 AM
  #186
A Ilievski's Avatar
hey can we see some pics of your tt-01 and also at the moment im trying to get adjustable upper arms
Old 06-28-2005, 02:41 AM
  #187
rays_tt's Avatar
Trader Rating: 26 (100%+)
i'm currently switching between black motor and silver can when i race. i want a stock motor to see weather its any good.
will my esc or gear ratio stuff up the stock motor? or will the esc be the only thing that stuffs up?
by the way what happens if your final drive ratio is too low or too high? at the moment on my TT i'm sitting on a 5.72 (55spur/25pinion)2.6trans ratio.
if i had a 58spur and 23pinion i'd fall into the 6.5-7 you were talking about.
rays_tt is offline
Old 06-28-2005, 02:51 AM
  #188
rays_tt's Avatar
i dont know if you werer asking for my TT or not, but i was bored so i posted it anyway.
rays_tt is offline
Old 06-28-2005, 02:53 AM
  #189
A Ilievski's Avatar
nice TT-01 what hop ups do you have
Old 06-28-2005, 03:01 AM
  #190
rays_tt's Avatar
its nothing special.
um.. i have
- alloy front and rear hubs
- aluminium drive shaft
- alloy heat sink
- full ball bearings
- metal motor mount
- carbon upper frame
- oil shocks
and im running a TEU101bk esc, take-off 27s, and 55spur with 25pinion.
the thing that bugs me is that i never crash but my wheel drive shafts (the thing you screw a nut onto to secure your wheel) keeps buckling (wobbles).
rays_tt is offline
Old 06-28-2005, 03:07 AM
  #191
A Ilievski's Avatar
that happens to me aswell i dont know what it is at the moment my hop ups are
blue aluminym shaft
58 spur with 25pinion
alloy motor mount
heat sink
high speed bearings
TRF shocks
carbon upper frame that i have to pick up from the shop
take off 22's
tie rod set
and there all genuin tamiya parts
and soon i wana get the adjustable upper arms
rear toe in up rights
steering set
and thats about it
ball diffs
front one way unit
Old 06-28-2005, 03:12 AM
  #192
rays_tt's Avatar
i got my oil shocks for free so im not complaining =]
all i want is the steering set, i dont know about the adjustables since my wheels wobble, because then they wont be as effective and just a waste.
i'll take RAYMAN's advice and pass on the adjustable upper arms, and maybe just get the tie-rod set.
by the way is toe-in the front more beneficial than toe-in the rear? or the other way around?
rays_tt is offline
Old 06-28-2005, 03:16 AM
  #193
A Ilievski's Avatar
um i think its more benificial for the rear to be toe in and the front to be toe out thats i think tho
Old 06-28-2005, 09:56 AM
  #194
I believe it's better to have toe-in front and rear. Toe-out can make the car a bit quirky. NEVER go toe-out in the rear (so I've been told).
Toe is quite a sensitive adjustment. Anything over 2 degrees in the rear is too much. Not too sure about front, but I had like 5 degrees of toe or something. really messed up the handling. a small amount of toe is good.
I actually still have the adjustable arms and find them somewhat useful for tuning. It's the front A-arms that tends to get all whacked out, but the rear is fine.
Core should be okay with the Tamiya ESC. Just watch out for overheating. Mine has not overheated so far, but if you gear is pretty high you might cause some major heat problems.
Old 06-29-2005, 06:41 AM
  #195
DraxXuter's Avatar
I ave a tt-01 too but if i buy balls bering and a new motor is it good?
And tyhis my tt-
Attached Thumbnails Does TT-01 has a potential?-my-tuned-car3.jpg   Does TT-01 has a potential?-my-tuned-car-001.jpg
DraxXuter is offline
