Motor rebuilding info needed
RCXotic.com has alot of useful articles on motor maintenance & basic techniques...
Re-time Your Motor
Solder Capacitors & Diodes
Dial-In Your Motor
Cut Your Comm
Re-time Your Motor
Dial-In Your Motor
Cut Your Comm
i have the following suggestions for you:
1. DO NOT LUBRICATE the v-shape guide on your lathe with bearing oil! use tamiya lubricating grease instead!
2. use 4 old cells, do draw power directly from a power supplier.
3. you have cutted the comm, add bearing oil on the comm, and do a very very thin cut.
4. use a comm cleaning rubber to unsharp the edges of the comm slot. do it carefully otherwise u will scratch the comm surface
just my 2 cents
just my 2 cents
Registered User
Yeah Moly is awesome, we coat our bullets with it for competition rifle shootiing, and the barrels stay cleaner, they last longer, and it keeps its accuracy longer, and cleaning is a breeze.
