Go Back  R/C Tech Forums > General Forums > Rookie Zone
Good dicharger >
Good dicharger
Good dicharger
Old 10-12-2004, 01:11 AM
Blackwrench™'s Avatar
Default Good dicharger
you guys know any discharger best for nicads and nihm?
Blackwrench™ is offline
Old 10-12-2004, 01:13 AM
Does the nimh batts packs needs to be discharge also? whats the best batt in the market interms of life and quality?
Old 10-12-2004, 03:07 AM
Speedie's Avatar
Most dischargers are about the same. Just make sure you get one with at least a 20 amp discharge and preferably 30 amp. The old trusty lightbulb discharger will work fine if it has an automatic cutoff.
The nimh cells still need to be discharged even tho they have no memory to them. The also need to be equalized at .09v before charging back up again. The current cellof choice is the GP 3300 nimh. Several matchers sell this cell, 90% of them are close as far as quality. Try picking one close to you for service and just to support your local RC scene. They also have alot of information your looking for on thier websites.
Speedie is offline
Old 10-12-2004, 09:19 AM
Novak Smart Tray, that is all i need to say
DerekL is offline
Old 10-13-2004, 04:02 PM
Cole Trickle's Avatar
You also need to say 20 or 30 amps , so the Novak cant stand alone.
Cole Trickle is offline
Old 10-13-2004, 11:46 PM
pink pac man's Avatar
deans bulb discharger/eagle cdc/novak smart tray are the best stuff..............i think
pink pac man is offline
Old 10-14-2004, 04:20 AM
what about the integy 30 amp one?
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
Aadolf is offline
Old 10-14-2004, 08:58 AM
What about Charger with discharger? whats you guys think. my buget is $150.
I try using 30 amp resistor? and checking it continously with my digital Tester. Is that OK? I stop practicing it though. since i got tamiya discharger. (i'm still not satisfied to the discharger though)
Old 10-15-2004, 07:26 AM
Oasis's Avatar
Trader Rating: 38 (100%+)
I dont use this feature on any of my chargers.The reason why is to much heat is dissipated during discharge.Heat = early electronic failure,even in the good ones.. I use a bulb discharger(one with a cut off device),a tray and a good charger.I would buy the best charger I can afford,save up some money and get a good tray(the novak)The only batterys I would get are the GP's(3300)The Chargers are a little more "connfusing" because their are so many feautures so many chargers Ac/Dc,Dc, Their are a few good ones in your price range.Integy has a few..16x4 AC/DC,16x2,Novak has the millennium chargers(DC only)LRP has the pulsars(DC only)Reedy has the Quasar's(really the same charger's as the Integy's)I would stick to one of these chargers..
Oasis is offline
Old 10-15-2004, 08:36 AM
rice's Avatar
if you have the budget gfx or a cdc will do.
rice is offline
Old 10-15-2004, 01:57 PM
Oasis's Avatar
He only has $150..I dont think you even get to look at one of those for 150.. I think the GFX and the CDC are a bit overpriced for most of us.Their are chargers out their for alot less money that charge your packs just fine,but with out some of the features.
Oasis is offline
Old 10-21-2004, 10:50 AM
Hog
I got a Turbo Tube from King Daddy Racing shipped over to the UK. Does what I need and looks a bit bling as well. 20Amp plus 5.4V cutoff wa about $70 or so, and that included shipping.
Hog is offline
Old 10-21-2004, 07:21 PM
DT-Skyline's Avatar
If u save up about $30 more, u can get the Integy 16x7 v6.. It's a really good discharger and charger..Can discharge up to 30 apms and charge up to 6.5 apms. Also has a Cycle System too to go through and help out ur dead cells. It can charge/discharge Ni-Cd and Ni-MH
DT-Skyline is offline
Old 10-22-2004, 01:16 AM
Not nessecarily (spelling?). It's true that heat do stress electronics, but if the design is well done, it's not a problem.
Old 10-22-2004, 01:22 AM
Many people have experienced that buying a cheap charger, means that the battery packs are fast damaged. Meaning it wasnt so cheap anyway...
A good alternative, is the LRP Pulsar Sport, which can be found for 100$. This rest of the money can be spent on a power supply.
Another alternative, might be to modify a computer power supply for this kind of use. It requires some soldering, but works fine, almost for free.
Or simply buy a used power supply.
Integy have some interesting dischargers, the Reactors. They comes in different models, with different disharging rates. They got auto cut off, which I think should be a mandatory requirement.
