Go Back  R/C Tech Forums > General Forums > Rookie Zone
need help with tuning >
Old 06-03-2011, 07:05 PM
downeyboy's Avatar
Default need help with tuning
hi i am new to the hobby 5 months now i have a tc5 factoryteam and would like to learn how to tune my novak balistic esc and how to gear the motor 13.5 car is slow could any1 help with the best gearing to use to improve performance
downeyboy is offline
Old 06-05-2011, 07:10 PM
MarkA's Avatar
Trader Rating: 21 (100%+)
Use this site to get a starting gear ratio: http://www.comeseethis.com/gearing/Default.aspx
Then, if your motor comes off the track cool and your track is fairly large, you can increase the pinion size to gain top speed.
MarkA is offline
Old 06-07-2011, 09:59 PM
downeyboy's Avatar
THANKS THAT WAS HELPFULL
Old 06-07-2011, 10:06 PM
downeyboy's Avatar
I HAVE A FRIEND HE IS RUNNING A MAMBA MAX ESC WITH A EZRUN MOTOR13.5 IN A TC5 IS THIS A GOOD MOTOR IF NO WHAT BRAND OF MOTOR WOULD YOU RECOMMEND MUST BE 13.5 OR 17.5
Old 06-08-2011, 08:06 AM
MarkA's Avatar
That motor should be fine for a 13.5 class.
MarkA is offline
Old 06-08-2011, 01:50 PM
On the chart you linked above, are the Castle CM motors equivalent to the NeuCastle 1406 series?
Thanks.
Sizzlechest619 is offline
Old 06-24-2011, 05:01 AM
comeseethis.com has been upgraded and replaced with www.rcgearhead.com. Now you can submit vehicles, motors, and your own gearing.
The new site averages all the FDRs that are submitted for a specific vehicle and motor (but you can still change it) to come up with the recommended final drive ratio.
I have also added a top-speed calculator. Just make sure you pick a tire, because if you don't, you won't get a value for the top speed!
I hope you like it!
Craig
CraigV is offline
