Gearing Question
Gearing Question
Hey guys,
I purchased a second-hand RDX PHI 08 and I'm putting an EZRUN brushless setup in it (http://www.hobbypartz.com/ez-60a-rc-...ar-system.html) and I was wondering what gearing you would recommend. I'm not going to be racing the car, just bashing it on tennis courts, etc. My main goal is to make sure I don't overheat the motor/esc. Would running a 20
T-23T pinion with the stock gearing be ok?
I'm running a Gens Ace 5000mah 40C 2S Lipo for my battery.
I'm just getting back into the hobby after numerous years (when I left ESC's were still "new" tech).
Thanks!
Matt
Thanks!
Matt
hi there,give it a run with the current gearing now and check temps of motor and esc every 2min.They should stay below 90 degrees celcius.If its cold or not close to it just repeat the process and change pinion untill you get the speed and temprature you want.but remember timing and punch mean heat.
whats your spur gear size? and google you cars name and look for its internal gear ratio and post it up.
Matt
Your motor can run hot if the pinion is to big or to small.
Your ESC will ONLY run hot if your pinion is to big.
To find the sweet spot gear so your motor and ESC are the same temp.
You need a temp gun, your finger will not work, drive for no more then 3min. at a time until you get your temps in the ball park.
I find it best to start with a pinion that is to small.
If you start with a pinion thats to big your motor and ESC will both run hot, that makes it hard to see whats going on.
I hope that helps you understand how to get to the right gearing as fast as possible.
Matt
Ah ok, that makes sense. So 90C should by the highest I can go comfortably? I have a temp gun already I'm just waiting on my radio to come in the mail to get this car going
In most cases the cooler the better if you want your stuff to last
PS
That motor you linked to is a 6000kv.
On two cell lipo's thats 44'400 rpm.
Your going to need to start with like a 15t pinion or even smaller.
I don't like using small pinions ether so I use the largest spur I can get in my car.
I use a 114 spur with a 24 pinion but I had to do some grinding to get the 114 to fit.
