Go Back  R/C Tech Forums > General Forums > Rookie Zone
RC Maintenance? (Brand new) >
Old 05-06-2011, 02:07 AM
Default RC Maintenance? (Brand new)
Hey guy, Brand new here. I ordered a Traxxas Slash 2wd that should be arriving on Saturday.
My question: (Aside from upgrading and mods) What kind of maintenance do I need to do on this thing? And how often? Any tips on breaking in?
Rooster2410 is offline
Old 05-06-2011, 03:11 AM
blis's Avatar
Maintenance is key..
If a nitro engine, then yes there is a breakin and many opinions on how to do it will emerge. The key is to expand the block and liners before firing it up and wearing the piston into the liner. It can be a painful task and wouldnt go astray to have an experience person assist you with it. What to do if you seize up the piston in the liner. Or where to position the piston after each cycle of the run-in process..
See here for an Epic version of just run in.
http://www.beachmumsracing.org.au/fyi/santalovesnitro/
Apart from that, the car should have a good once over, checking that your servos are trimmed correctly and all is screwed together, battery charged, ample room at a park to run in etc etc.
I'd suggest hunting thru forums and asking others with a similar model things you might want to check before proceeding
Read up, ask and prepare it well and it will serve you well later on. It's not voodoo or magic, it's all straight forward but takes many of us years to perfect every attribute regarding the prep of a new model.
blis is offline
Old 05-06-2011, 08:41 AM
nadan805's Avatar
Clean the car every few runs with wd-40 and an air compressor. Check the spur/pinion mesh every couple of minues while running. I use blue threadlock for screws going into metal and superglue on screws that go into plastic. Have fun!
nadan805 is offline
Old 05-06-2011, 05:05 PM
PaulL5156's Avatar
usually what i notice with RTR's that come right of the box is that some screws on the chassis or the nuts holding the tires in place usually back out and become loose. So, double check all screws that they are tightened snugly so you dont have to look for lost screws.
PaulL5156 is offline
Old 05-06-2011, 05:23 PM
nadan805's Avatar
That's a good one. There's some guys who will tear the whole car apart if it's an RTR for that reason. I'm not that crazy though...
nadan805 is offline
Old 05-06-2011, 06:26 PM
Thanks alot guys. Good to know.
