Go Back  R/C Tech Forums > General Forums > Rookie Zone
Forward / Reverse Problem >
Old 05-01-2011, 07:25 PM
TWRC's Avatar
Trader Rating: 14 (100%+)
Questions?? Forward / Reverse Problem
My Associated used to go really fast. When it didnt one day, i realized that it went slower going forward but extremely fast in reverse. I tried reprogramming the esc several times and again with the original remote. You can hear the difference when you are holdingit and revving it in the different directions. Any ideas on what's wrong? I didnt change any settings, it just was like that one day
TWRC is offline
Old 05-01-2011, 08:56 PM
racer53's Avatar
What ESC and radio are you using...
Just a thought: You might check the EPA on the radio...
racer53 is offline
Old 05-02-2011, 12:52 AM
hey i had this problem with my tz superstock motor,I found it was the comm and the brushes were worn.get a comm cut and new brushes it should be sweet.
Hotbodiesd4 is offline
Old 05-02-2011, 04:12 AM
TWRC's Avatar
Post
The stock XP2 or Tamiya's AdSpec GP for radios with associated's xps micro esc
TWRC is offline
Old 05-02-2011, 10:13 AM
racer53's Avatar
xps micro esc
Okay, so we're talking about one of Associated's 18th scale?
racer53 is offline
Old 05-02-2011, 12:54 PM
TWRC's Avatar
Post
Yes. All is stock except for the suspension all around but that shouldnt make any difference
TWRC is offline
Old 05-02-2011, 07:42 PM
racer53's Avatar
Hmm...I have to admit i'm not sure...
You could post this in the Electronics/Radio section, might get more replies...imo.
Good Luck, Racer53
racer53 is offline
Old 05-02-2011, 08:18 PM
nadan805's Avatar
Sounds like you may need to play with the throttle channel reversing and or swap the neg and pos motor wires.
nadan805 is offline
Old 05-03-2011, 06:05 PM
TWRC's Avatar
Post
ive tried flipping the throttle reverse and that doesnt do anything besides change the way you have to push the trigger. do you mean change them where they are soldered to the motor or connect + to -?
TWRC is offline
