what kv?
Old 04-25-2011, 10:25 PM
datflipkid's Avatar
Default what kv?
which kv is best for what?
datflipkid is offline
Old 04-25-2011, 10:42 PM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
what car/truck do you have and what do you want to do with it? Do you have a brushless esc, which one??
racer1812 is offline
Old 04-26-2011, 11:37 PM
Basically as I understand it, a high kv number equals a low turn motor.
Low turn is for going fast on a track, say like an onroad 1/10 scale touring car.
And vice versa with a high turn/low kv number. They are good for off road vehicles... (more omph at take off, better acceleration, but a lower topspeed)
So for bashing I would recommend a lower kv number,around 27-3000.
For on road racing you're looking for higher numbers.
Be warned though, the higher kv you get the faster the car will go, but it will also be that much more difficult to control...
I'm just starting out in onroad touring car racing and I'm beginning with a 17,5 turn sensored motor.
Once I get the hang of it, I'll most likely get a 13,5 turn and so on....
Hope that helps.
Att. Pro's, If I'm wrong here please feel free to correct me ;-)
Coach-Z is offline
Old 05-01-2011, 08:26 AM
datflipkid's Avatar
looking to race it on the indoor offroad track
i plan on getting a tekin rs and I have a b4.1 buggy
Old 05-01-2011, 09:40 AM
Super Moderator
racer1812's Avatar
If that's the esc you're getting then look at motor turns not Kv. Sensored motors in general are rated in turns, anyway, Stock or mod racing? Ask your track but most run 17.5 motors for stock and mod is normaly open to any motor. A 13.5 or 10.5 is plenty if you're new to mod buggy.
Old 05-01-2011, 12:12 PM
Scale? On road? Off road? Main use?
vstrok is offline
Old 05-01-2011, 01:46 PM
datflipkid's Avatar
read my second post
i guess I'm looking at turns though, i dont even know what class I should be in stock or modded
again, running on a 1/10 rc10b4.1, off road indoor track for racing
Old 05-01-2011, 03:58 PM
Super Moderator
racer1812's Avatar
Talk to the guys at your local track but if your even remotely new to racing you'll likely want to run in the stock class. Mod is not the best place to start racing.
Old 05-01-2011, 06:17 PM
haganracing77's Avatar
Trader Rating: 18 (100%+)
Hope that helps.
Lower KV can be as fast, 2650KV or 2200KV is what you could use in your EBUGGY... KV is the RPMS a motor turns.. A 17.5 brushless or 12 turn brushed motor is what you would run in a stock 2wd class, My 4x4 slash has a 3800KV motor in it. 55 turn is what you would run in a rock crawler, go down from there.
haganracing77 is offline
Old 05-02-2011, 02:54 AM
RCaddict0's Avatar
Trader Rating: 85 (99%+)
I would look at 3000kv to 4000kv. Any less will be slow on Nimh or 2s lipo.
RCaddict0 is offline
Old 05-02-2011, 03:14 AM
RCaddict0's Avatar
. Double post
Old 05-05-2011, 06:43 PM
jeremy reed's Avatar
what turn is the castle 3800 equal to?
jeremy reed is offline
Old 05-05-2011, 10:52 PM
Super Moderator
racer1812's Avatar
If it's the 4 pole motor it really doesn't compare to any "turn rated" motor, apples and oranges really.
