Go Back  R/C Tech Forums > General Forums > Rookie Zone
learning my carbs >
learning my carbs
learning my carbs
Old 09-08-2004, 05:19 PM
hareball's Avatar
Default learning my carbs
I just bought this truck and it was modified and came with no manual to look at.
is the top screw the high speed and the bottom screw the low speed adjustment?
thanks for all help
hareball is offline
Old 09-08-2004, 05:43 PM
terrible ted's Avatar
I belive that the top one is high speed and the bottom is low.
terrible ted is offline
Old 09-08-2004, 06:23 PM
hareball's Avatar
thanks
figures the carb that needs adjusting is next to that carb and very hard to get to
hareball is offline
Old 09-08-2004, 07:20 PM
ctardi's Avatar
yes that is correct, just remember, adjust in 1/8th turn increments only. adjust 1/8, then see how it works, repeat as nesicary
ctardi is offline
Old 09-08-2004, 07:33 PM
hareball's Avatar
thanks!
is there a general rule for a stock setting? I have the high speed settings both at 4 turns out and that is working pretty good but I want to tune both motors in at idle.
hareball is offline
Old 09-09-2004, 08:37 AM
ctardi's Avatar
Do you know what kind of motor it is? or if it's stock, you can go to the web page of the company that made the truck, and download the manual. Mine is usually around 3 turns back. But, remember, no smoke = bad! if you spit or drop a few drops of water on the head, it shouldnt sizzle away right off the bad, it should stay for about five seconds, after you have just run the truck and heated it up. If it stays longer, go a bit leaner, and shorter, richer.
ctardi is offline
Old 09-09-2004, 08:44 AM
onnetz's Avatar
that is the trx 2.5 motor that comes stock with the tmaxx..
what you have labeled as the low speed needle is actually your idle screw.
the low speed needle is on the other side.
this link should get you going..
http://www.traxxas.com/support/pub/trx_sl_tuning25.htm
onnetz is offline
Old 09-09-2004, 05:28 PM
hareball's Avatar
thanks for the help, guys!
ctardi, the truck has twin trx 2.5's
onnetz, thank! that link will help alot
hareball is offline
Old 09-12-2004, 04:42 AM
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Default are u sure its LSN?
are you sure its LSN?
i thinks it is the idle needle the needle that control the carburator drum/slide opening....
correct me if i am wrong...
coz to me LSN located at the end of the 'accordian' thing.... connected to the carb drum/slide not the at side....
hmmmmmmmmmm
mop
mop_iko is offline
