Go Back  R/C Tech Forums > General Forums > Rookie Zone
which one first?brushless or lipo >
Old 03-24-2011, 07:48 PM
Default which one first?brushless or lipo
ok trying to decide which to get get first a brushless setup or lipos and a charger.I have a 2wd brushed slash xl5 with a lipo alarm.I'm thinking get the lipo stuff first for longer run times,but also want the brushless set up for more speed and less maintenance . I mostly just bash but maybe try a little racing once I get better at driving . now just looking for opinions.
benhiers is offline
Old 03-24-2011, 07:59 PM
Dadic 78's Avatar
Well I think you're going to have to get the Brushless motor/esc first, as your brushed ESC will likely not handle a LiPo battery.
I'm not sure which ESC you have in your Slash, but I'd ensure it's LiPo compatible before you go hooking a LiPo up to it.
Dadic 78 is offline
Old 03-24-2011, 08:23 PM
tbrymer's Avatar
Default brushless or lip
I would suggest you look at the specifications of your brushed speed control and if it will support up to 8.4 volts(2s lipos are usually charged up to 8.4v), then I would go lipo first. I know all of my brushed speed controls work fine with 2s lipos (7.4), and I have a Tekin, Novak, and an LRP. I recently went through the same process after being out of racing for about 7 years. If you plan to race, you may want to go brushless soon after you go to lipo, depending on the rules and requirements of your local track classes. Hope this helps.
tbrymer is offline
Old 03-24-2011, 08:28 PM
ZiG-87's Avatar
Brushless will get you a greater power increase.
ZiG-87 is offline
Old 03-26-2011, 01:36 PM
Trader Rating: 21 (100%+)
The XL-5 is rated 4 to 8 cells so it will not have issues with the voltage of a 2S lipo. The newer XL-5s have a lvc now, you just have to activate it when you change to lipo. See your manual for the details.
Go lipo and get a good charger, then the brushless setup to go with it.
Duster_360 is offline
Old 03-29-2011, 03:14 PM
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default I Agree...
I agree with Duster_360 if you already have a lipo cutoff built into the speed controller then I would go with the Lipo and good charger. You will gain more power and longer run time from a good lipo and charger. If you add a high power brushless system without having lipos to power it, you will not get the most from that investement.
JFuel11 is offline
Old 03-29-2011, 03:47 PM
Buzz65's Avatar
I'm running a Kyosho Ultima SC. The stock esc can be programmed for either nimh or lipo's. My thoughts were, I'll get the Lipo's first... That will provide me with longer run times to improve my driving/control of the vehicle. Then, once I get to a point where my driving isn't the main limiting factor, then I'll switch to a higher powered, more responsive brushless system. Sort of a reward for putting in the time w/the old setup. The bonus is also less maintenance then!
Good luck on whatever you decide.
Buzz65 is offline
Old 03-30-2011, 04:36 AM
daverobbo5's Avatar
Trader Rating: 45 (100%+)
Go Lipo I bought Lipos for both a brushed set up on a Tamiya basher and a brushless for off road 2wd racing. the lipo on a tamiya 540 is like a running a 23 turn on NimH.
The lipos fall from 8.4v to 6.4v and you'll notice the power loss and stop running. i usually stop at about 6.8v becuase it just looses the awsome power. i don't run lipo cut off on the tamiya.
daverobbo5 is offline
Old 03-31-2011, 01:55 AM
dragon68's Avatar
go for lipo and lipo charger for longer run time ....bashing with brushed until you are ready to handle more power , that time ..change to brushless ..just 1 cent ...
dragon68 is offline
