Go Back  R/C Tech Forums > General Forums > Rookie Zone
why charge at 4 and not 5 amps >
Old 03-23-2011, 06:48 PM
Default why charge at 4 and not 5 amps
hi everyone have a problem guys. i have a li-power 11.1v 3s 5400 mah lipo and a passport lipo 6s ac/dc charger made b dynamite. now my problem is when i se m amp to 5 and start the charger it switches over to 4 amp when i he 5400 mah battery what is up with that ?
shadowm891 is offline
Old 03-23-2011, 07:12 PM
Your charger's power output is limited to 50 Watts. Voltage x Amps = Watts.
You have a 3S pack: 3 x 3.7 = 11.1 volts. So, lets say your pack is discharged so it's at 9 volts. Your charger can charge it at a maximum of 50 Watts / 9 volts = 5.5 amps ( well 5A really since that is your chargers other limitation). BUT, your battery voltage keeps getting higher due to charging so once it gets to 11.1 volts, you can only charge at 50/11 = 4.5A. Once it gets to 12 volts, you can only charge at 4.16 Amps.
Your charger is probably not able to auto-adjust the charge rate during the charge so it just picks 4 amps from the get-go.
SC8E is offline
Old 03-24-2011, 02:45 AM
is that bad on the battery i mean the charger ?
Old 03-24-2011, 07:16 PM
Are you asking if setting a 5A charge rate is bad for the charger? I don't think so, IF the charger is automatically reducing the setting to 4A.
SC8E is offline
Old 03-26-2011, 01:41 PM
Trader Rating: 21 (100%+)
The model #4066 Passport charger is a 50watt charger and that's why you're experiencing the charge current reduction you're seeing. The charger reduces charge current to stay under its 50watts max output power.
Duster_360 is offline
