SC10 Battery tray. PLEASE HELP!
I have a brushless SC10 non FT and Turnigy 2S lipos. My problems is the battery tray will not close because of the thickness. Any ideas? (Mods or purchasing something thats adjustable.)
You try adjustable velco straps?
Where would I loop them through?
Longer screws in the rear of the battery holdown.
for those turnigy batteries that have the wires on their longer sides, you'd have to cut out a small bit of the side of the battery tray.
anyway, go for velcro straps (Align has some pretty neat straps), cut 2+2 holes on the sides of the battery tray with a dremel or skil multitool, close to the chassis. I've done this on both of my SC10s, velcro all the way!
I run them some times and I use the carbon battery strap. I still have a little play though. I just use a little bit of foam under it.
