Where to measure ride height?
Recently purchased a RC8T & wanted to know where exactly do I measure from the chassis to the ground on ride height clearance? My factory spec sheet calls for "FRONT" 38mm "REAR" 44mm. Also to be sure is HOW to adjust the ride height. I don't have those fancy rig height scales but do have a 6" mm ruler...appreciate your help in advance.
It's much easier with a ride height gauge. All you do is drop the truck from 6" race ready, set the gauge to the desired height, and slide it under the front or rear of the chassis. You measure it right under the front and rear of the chassis.
To adjust ride height you adjust the shock collars, Screw them down for more ride height and up for less. Hope this helps!
