Go Back  R/C Tech Forums > General Forums > Rookie Zone
newb - I think i need new tires.. >
Old 08-23-2004, 12:17 AM
Default newb - I think i need new tires..
And rims Any suggestions for tires? Or do i just go to tamiya.com and pick some replacements?
DC5R is offline
Old 08-23-2004, 04:15 AM
Go to your local hobbie some and get some HPI's i love them had them for ever. Stick with some nice and cheap rims. And dont forget to glue the tires on!
Cooliok is offline
Old 08-23-2004, 11:55 PM
Qwiglee's Avatar
I highly reccomend Sorex tires. They have good grip and long life. I have went through almost every tire HPI makes and never found any as good as Sorex. Get whatever 24mm wheel you like but dish wheels from any manufacturer are probably a good choice.
Qwiglee is offline
Old 08-24-2004, 07:12 AM
MrRolla's Avatar
Trader Rating: 30 (100%+)
I also recomend Dish wheels, try and get some speedmind ones as they are very strong. I picked some up online for $6-7 for 8 rims.
MrRolla is offline
Old 08-25-2004, 01:14 AM
Neil Rabara's Avatar
Default Re: newb - I think i need new tires..
You are in dire need of new tires and wheels. I recommend premounted tires and wheels because most have been decently glued.
Neil Rabara is offline
Old 08-25-2004, 02:03 PM
calstarjig90j's Avatar
Defintely need new rims and tires. Things will only get worse. I ran some tires way beyond their lifespan and the they blew up on me, inserts ripped out and whole car went ballistic. Better change them now before you break something else. Hence better now than later.
calstarjig90j is offline
Old 08-27-2004, 10:48 PM
I think I need a 101 on glueing tires. I cant use these new RJ tires, foam rips out and tire comes off the wheel when i corner aggresively. THis doesnt happen with my old non-glued tires.
The new tires are on these wheels because the new wheels I got are a bit narrower (24mm i believe) than these white ones (26mm); and these new tires are so much meatier than my old ones. Guess I will have to get some dish wheels or maybe sell these tires since I dont think I really need them.
DC5R is offline
Old 08-29-2004, 06:54 AM
Wency_TA03R-PRO's Avatar
I agree with you bro... Also get a new nice rim... was that a protoform rim that you are using in the picture?..
Wency_TA03R-PRO is offline
Old 08-29-2004, 01:13 PM
ctardi's Avatar
what kind of glue are you using?
ctardi is offline
Old 08-29-2004, 01:14 PM
ctardi's Avatar
his are foam tires, no inserts
ctardi is offline
Old 08-29-2004, 01:39 PM
My old tires werent foam, they just didnt have inserts, but my new tires have foam inserts I'm just using tamiya model glue. So can I put these wide tires on my 24mm rims if I glue them properly?
DC5R is offline
Old 08-30-2004, 12:10 AM
ctardi's Avatar
you want to be using CA glue. Forget what it stands for, but it's about twice as strong as super blue
ctardi is offline
