Go Back  R/C Tech Forums > General Forums > Rookie Zone
reciever battery help >
Old 08-08-2004, 12:05 PM
RebelRacer's Avatar
Default reciever battery help
I have just bought a brand new reciever pack, and it has been on the charger for 3 days straight, but when i hook it up to my reciver, I get nothing, like the batt is dead.
please help me out here.
Kyle
RebelRacer is offline
Old 08-08-2004, 02:43 PM
Wency_TA03R-PRO's Avatar
Exclamation
What charger did you use?.. does your charger has a LED light (flashing/blinking) indicating that its in charging mode? Do you have a multi meter you can test each cell wether they are charged or not.. have you check on the wire going to the receiver pack it might have an open/cut wire either on the 2 wire if the batts are not charge. If you done check all these item I think its better to talk to the shop/person where you boght it for possible replacement of the stuff...
Wency_TA03R-PRO is offline
Old 08-09-2004, 04:58 AM
RebelRacer's Avatar
no, its just a little wall charger, where the solid light is supposed to get dim when the pack is full. I'll chcke my wires again and get back with you.
Kyle
