Pinion Query for e-revo VXL
Hey, basically I'm going to be running lipo batteries in parallel and wondered if I necessarily have to switch to the 23t pinion. Also I noticed it said in the instructions to only run it on flat surfaces, I mainly do bashing with my truck, ramping it off all sorts so should I change it or stick with stock? Cheers
Excellent, thank you for the response. This is good because I'd of had to have either drilled and tapped the grub screw or glued it to get it out so this saves me a job.
