traction and handling
ok im new, and i need help. 3 week old SC10. first of all i am fish tailing on acceleration and it seems a little unstable, i have replaced the rear tire with some traxxass and it got a lil better. but im still spinning out a lot and spinning in corners. suggestions please
Pull the diff and put 10k or 15k associated diff oil in it. Put the diff back in and say hello to rear stability. I chased mine all over until I put 10k in it and it is still a little loose but I like it. I think 15k would be better for a newer driver. This will make the truck not diff out in corners and give more bite. The reason you are fish tailing is due to a little too much motor, and getting on the gas to fast causing the diff to diff out and spin one wheel causing a loss of control. The thicker diff oil will fix this by making it harder for the diff to diff out.
Tires make a big difference especially for racing applications. On my SC10 I didnt used black grease in the diff. I ran 100k OFNA diff oil just on the gears and the handling was a night and day difference. Also shock setup will play a difference to in handling and steering of the truck. Sometime it just could be the track conditions were the track is drying out and loosening up.
-softer rear tires
- suspension bias... try 60 wt oil front 40 wt rear it'll slow down the front end a bit and give you more stability
- weight in the rear,... adding weight behind the battery, in front of the transmission, even strapping some to the rear bumper assembly will help rear traction...
- if your esc/radio has expo you can dial some in to soften the initial punch as well so you don't spin out as much on initial trigger pull...
try messing arround with the rear toe blocks that came in the box
the bigger the number on them will give u more foward bite but loose a little side bite. i currently use the 3.5 on my sons truck.
I might or may have jacked the thread, but I'm wondering...
What's the best method for getting at your Gear-Diff to work on it?
Do I need to remove all the parts around it prior to getting at it?
Lower the rear ride height a little so the dogbones are level or just below.
Increase in traction and stability!
