Go Back  R/C Tech Forums > General Forums > Rookie Zone
Discharging Batteries?? >
Old 09-03-2010, 11:02 AM
Zac_with_no_K's Avatar
Questions?? Discharging Batteries??
I have a couple 6 cell NiMH batteries for a 1/10 TC..
Does it really make a big difference if you don't discharge the battery when your done using it?
What will happen if I don't discharge them?
I would rather just top them off before a race and stick them back on the charger when they start getting low(after it cools off)
Zac_with_no_K is offline
Old 09-03-2010, 11:06 AM
RC Dad's Avatar
Trader Rating: 26 (100%+)
With Nimhs you don't dischargge before storage, store them at 50-70% charge. They should, however, be discharged prior to charging. Failing to do so will cause them to lose run time.
RC Dad is offline
Old 09-03-2010, 11:26 AM
D-Rek07's Avatar
This is true but when you discharge them you need to leave a little bit of juice in them.
D-Rek07 is offline
Old 09-03-2010, 12:38 PM
Trader Rating: 21 (100%+)
By not discharging, you are 'training' them to use only that portion of their capacity that you're recharging - this is the 'memory' they are infamous for.
I discharge mine to 0.9v/cell or 5.4v for a 6 cell pack.
Duster_360 is offline
