Revo help
Old 07-23-2010, 02:55 PM
Default Revo help
Hi Guys
Im new to this forum stuff so hope im in the right place.I have recently purchased a 3.3 revo and am having a problem getting going.
After haveing problems with idle/fuel mix i read manual and turned mixture screws back to factory and reset optidrive and idle controls on transmitter to 0 exactly how it said.
Revo starts perfect on the ez start but all 4 wheels are spinning and i cant stop them if i apply any restriction or apply brake revo just stalls plus it will only start of ground because of restriction on ground.
Any help would be really appreciated as im so confused.
rwooduk is offline
Old 07-23-2010, 06:51 PM
jbright33's Avatar
Trader Rating: 15 (100%+)
sounds like a clutch spring broke and you clutch is engaging all the time. pull your motor out and take your cluch bell off and inspect the clutch.
jbright33 is offline
Old 07-24-2010, 06:32 AM
Trader Rating: 21 (100%+)
Either that or the idle is simply too high - adjust the idle screw to lower the idle, if it won't maintain ~1mm gap in the carb for idle, then there is some kind of linkage prob.
Duster_360 is offline
Old 07-24-2010, 10:06 AM
Default revo problem
Thanks for advice guys i have taken air filter of and checked out gap in carb on idle after adjusting the low idle screw i have at least 1mm gap in carb with nice idle speed but still have the problem of wheels turning revo runs and starts well just this dam problem of wheels turning.
Im thinking it could be clutch could any one help me with advice on what to do next.
rwooduk is offline
Old 07-24-2010, 10:53 AM
Then its time to check the clutch and see if the spring has broken or come off.
Easiest way is to remove the engine - that will give you access so you can pull clutch bell off and check shoes/spring.
