Go Back  R/C Tech Forums > General Forums > Rookie Zone
I need help SC10 gear mesh and spur gears >
Old 07-05-2010, 06:13 PM
built 4 speed's Avatar
Default I need help SC10 gear mesh and spur gears
I bought a bunch of new stuff in early spring I'm just getting around to putting on my truck
I have a robinson Superspur gear I cant get to fit right
in between the slipper pad
the hole is huge but on the stock gear it fits perfect
tips tricks suggestions????
I tightened the spring all the way and the pinion just spins
built 4 speed is offline
Old 07-07-2010, 05:15 PM
G33Kster's Avatar
I don't quite understand the problem you are having. Is the hole in the spur too large for the slipper shaft? If it doesn't fit right, I'd say just get a spur that does fit, they're only a few bucks.
G33Kster is offline
Old 07-07-2010, 06:12 PM
Kent Beal's Avatar
Trader Rating: 72 (100%+)
Going by the picture on tower hobbies site, there is a bearing that is supposed to in there.
You realize thats 32p not the standard 48p spur? It was orginally made for the rc10gt2.
Kent Beal is offline
Old 07-08-2010, 01:49 AM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Kent he's got a thread over hear too....
http://www.rctech.net/forum/electric...help-sc10.html
racer1812 is offline
