diffs ?
i took apart my truck yesterday because when i was driving it earlier i heard squeaking from the rear tires. after words i brought it back inside and started to play with it to find were the sounds were coming from and it was the tranny. i took it all apart and i found that my bearings were real dirty, also i took the diff apart to inspect it. nothing looks bad but i want to clean it really well before i put it back together.
i was wondering what grease i should use and what wieght? also i was wondering if i could get some advice on what should i use to clean it? also how do i clean the bearings, meaning do i just wipe them down or do i take them apart as well. please help.
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
then go here to get to know how to clean those bearings.
thanks but?
thanks for the help that you all have given me but i still need to know what do i use to clean the old grease off of the diffs and what do i use to clean the bearings?
Motor spray works well for both. After cleaning your bearings make sure you oil them with a light oil(trinity royal oil).
Suspended
When it comes to bearings I like to soak them in lacquer thinner for about an hour or so, use a little container like an old r/c paint bottle with a good lid,shake the bearings lightly every once in a while to remove all the old grease or lube.
remove the bearings from the thinner and let dry on a paper towel or rag. When dry oil with a light oil for bearings and put them back in your car
Now wasn't that fun? just think you get to do it often
Most of all have fun and enjoy the hobby
thanks man i appreciate the addvice. that really helps. and heck yeah i enjoy the hobby. working on it is the best part. thanks
