Go Back  R/C Tech Forums > General Forums > Rookie Zone
SC18 controller locks wide open >
Old 06-20-2010, 10:11 AM
visual_rabbi's Avatar
Default SC18 controller locks wide open
I have two new SC18s. One works as expected. The second unit has an intermittent issue with the transmitter Team Associated XP3-SS. Out-of-the blue, the throttle locks up wide open. Fortunately, it has not been in a situation where it crashes into a wall or someone. To fix the issue, I turned off the car and the Tx. Then power them back up and all is normal.
It's only happened three times in the last several days. Any ideas on what the issue might be?
visual_rabbi is offline
Old 06-27-2010, 01:56 AM
I would check batteries in radio,if good,than i would say their is a problem with either esc or radio.
lionfish71 is offline
