NS12 S5 --> V-One-S
Hi there guys, I just got the novarossi engine, I've noticed that the shafts are different, so how would I go about installing onto my v-ones-s ie wat do I have to change...
[My VoneS is still pretty stock]
You'll either have to swap out the shaft or get another engine.
If the carbs are the same, it should bolt right in, like the original.
If not, then you are looking at either getting a repalcement carb of install a special upper chasis, tank and servo horn/connecting hardware.
It can be done, I have.
