A couple newbie questions
First question. Does the length of the antenna on the receiver need to be a certian legnth? Can any extra be cut off?
Question two. What is the best way to make sure the mesh is right between the spur and pinion gear?
Thanks in advance for any help!
Antenna length: dont cut the wire ! The radio wont work correct afterwards, if it even work....
Mesh: There should be some play between the spur and the pinion, but not too much. A normal piece of paper should be able to pass between the gears... Maybe others can explain it better.
Thanks for the info. I figured that to be the case with the antenna wire. What do you do with the extra antenna wire?
I go by the black myth of 18 inchs.
Second question. It should have backlash. A small amount of play. I would say with the motor srews on and slightly loose press the gears together and ther roll the tires a half turn and tighten.
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
can u rephrase your question again?
Regional Moderator
before tightening the motor in place. Place a small slip of notebook paper between the spur and pinion gear. Press them together until you can just remove the paper. Then tighten the motor mount screws. This should give you the correct amount of backlash
always use locktite on metal to metal sqrews
Since I can't tell if anyone answered the question about the antenna wire, here goes: wrap it in a TIGHT spiral around the TOP of the antennz tube then use shrink tubing to hold it there. Should work for you, does for me.
it works for me also!
a bit of OT, but how hard isit to replace the antenna wire ?
mine has busted, bit of copper wire sticking out. i dont think it will last too long. so is that a way to change it ?
