Go Back  R/C Tech Forums > General Forums > Rookie Zone
Will these electronical equipment work on my Micro RS4? Please Help! >
Old 03-18-2002, 11:23 AM
Default Will these electronical equipment work on my Micro RS4? Please Help!
Hi!
This is my first time getting an electric, so I am wondering:
http://www2.towerhobbies.com/cgi-bi...gm?Q=1&I=LXASX2**&P=M
http://www2.towerhobbies.com/cgi-bi...=1&I=LXZS09&P=M
One is the transmitter, receiver, and servo, and the other one is the ESC. Will both of these work together, are they compatible?, and if so, will they fit on my Micro RS4 with no problem?
thanks SO much
rawber
rawber is offline
Old 03-18-2002, 11:53 AM
fatdoggy's Avatar
Your links didn't work when I clicked them. Just tell us the name of the gear and we can help.
fatdoggy is offline
Old 03-18-2002, 12:06 PM
sorry here is link
http://www2.towerhobbies.com/cgi-bin...m?Q=1&I=LXASX4**&P=7
rawber is offline
Old 03-18-2002, 12:26 PM
fatdoggy's Avatar
The TX RX and servo will work fine. As for the futaba esc's I'm not sure, I've heard of people buying them and being really happy with them in there micro but I've also heard of people buying them and having them not work with the standard 4 cell setup. If your running 6 cells in your micro it will work fine but I'm not sure about 4 cells. It should all fit under the body if your using one of the sedan bodies but I doubt it will fit under a body like the viper. If your running 6 cell's strait from the start you'll have no probs but if you try and run 4 cell I have no idea what the out come will be.
fatdoggy is offline
Old 03-25-2002, 01:50 PM
Evil_S10's Avatar
Unhappy
read up on what you're buying and make sure it can handle a 4 cell or a 6 cell setup.
Evil_S10 is offline
Old 04-01-2002, 11:25 PM
actually, same question.
I've got a Novak Elektra. Will this work?
dugrant153 is offline
Old 04-04-2002, 07:24 AM
Im sorry, i dont think the elektra will work, its rated for 6 cells only, no higher, no lower.
However i have the futaba MC230CR, very small already comes with small guage wires suitable for the micro.
It is rated for 6-7 cells but i run it fine off of 4 1.2 volt brick cells from a cell phone, there only rated at 420 mah but there smaller than the ofna cells!
SteveRuff is offline
