Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 02-12-2010, 09:25 PM   #1
Default Bullet Plug
Hi,
I was wondering if there are any problems of adding bullet plugs between the ESC and brushless motor? Want a easier way to disconnect the motor from the ESC when necessary.
Thanks.
cvccsi is offline   Reply With Quote
Old 02-13-2010, 12:10 PM   #2
Originally Posted by cvccsi View Post
Hi,
Thanks.
Well my new Velineon came with the gold plated bullets already wired on, so if that's any indicator. I use bullets on a lot of things for their ease, but I have heard that they wear more quickly than a Dean's etc. I don't think their resistance is all that bad either. Whatever you decide to do, just check it occaisionally to see if certain parts are heating up faster than the others. And hopefully other people will drop by to add their advice.
Smuffy is offline   Reply With Quote
Old 02-13-2010, 12:56 PM   #3
Trader Rating: 21 (100%+)
All the Castle esc/motor combos are delivered this way. It makes it easy reverse the motor direction if needed by just switching any two of the motor/esc wires.
Nothing wrong with setting it up to run this way. I don't think you'll be unplugging often enough to be concerend about quality bullet connectors wearing.
Duster_360 is offline   Reply With Quote
Old 02-13-2010, 05:10 PM   #4
Thank you all the for feedbacks.
Old 02-17-2010, 03:45 PM   #5
Chimer's Avatar
Trader Rating: 26 (100%+)
Check the plugs priodically to be sure they still stay together tight enough so they don't disconnect while racing, I have seen this happen at the track. The plugs wear out from being plugged in and out so many times and then they need to be replaced.
AE:B5r,B5m,TC6.1,Team Losi:JRX-2,Tamiya Mercedes-Benz 1838LS,Traxxas Slash
Chimer is offline   Reply With Quote
Old 02-27-2010, 09:55 PM   #6
Toh WL's Avatar
it also depends on the user how frequent they swap motors. surely the plug gets loose much faster.
Toh WL is offline   Reply With Quote
Old 03-02-2010, 10:52 PM   #7
kk4hg's Avatar
Send a message via ICQ to kk4hg Send a message via Yahoo to kk4hg Send a message via Skype™ to kk4hg
Who is the honey in your avatar....DAMN!!
kk4hg is offline   Reply With Quote
Old 03-03-2010, 11:36 AM   #8
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Puting Bullets between the ESC and motor is a convenient way to swap motors quickly without having to solder.
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 03-05-2010, 09:51 PM   #9
Toh WL's Avatar
haha... who are u looking for?
Bullet Plug Help Chris Gierse Electric Off-Road 9 11-28-2009 12:57 PM
**BULLET TOWN RC 2009 SCHEDULE** David Wall MSRA (Memphis, TN) 303 07-06-2009 09:31 PM
