motor
Old 03-12-2002, 06:03 AM
Default motor
Can you put an O.S 4-stroke into an HPI Nitro MT
integrashowcar is offline
Old 03-12-2002, 07:57 AM
fatdoggy's Avatar
With some pretty serious modification it could be possible. (I think)
fatdoggy is offline
Old 03-12-2002, 08:28 AM
what mods would i have to do.....it wont like bolt on....?i know i gotta reinforce everything, thats why i have every part coming in aluminum...some here already
Old 03-13-2002, 03:00 AM
fatdoggy's Avatar
To tell you the truth I have no idea, I not a nitro guy(I said with some modification because a 4 stroke is alot bigger then the original .15Fe and so you would prolly have to get the .21 conversion and then mod it from there). Your best bet would be with the hpi crew at www.hpiracing.com go and ask on the truck forum I'm sure you'll get responces. Good luck.
P.s. I don't think it will just bolt on as there is no .26 conversion for the MT, you might be able to bolt on kyosho .26 conversion from there tourers but then again I not sure.
fatdoggy is offline
Old 03-13-2002, 05:41 AM
well im not signed up for HPI so......maybe later...Thanks for the help though....
