battery
Old 03-04-2002, 06:17 PM
battery
How long should I charge a 1.3mah 12volt lead sealed battery?
RCdave is offline
Old 03-05-2002, 03:20 AM
I would charge it for about 1-2 seconds-that's it! You also need to factor in what amp rate you want to charge at. If it was my battery, I would charge it at .001A with the delta peak value set to .01mV. Good luck and happy racing!
ZER01 is offline
Old 03-06-2002, 07:53 PM
Unhappy
oops...I mean 1.3Ah not mah
RCdave is offline
Old 03-06-2002, 08:05 PM
Unhappy
RCdave is offline
Old 03-06-2002, 08:36 PM
Trips's Avatar
Trader Rating: 16 (100%+)
The charge time will depend on the charge rate. For a 1.3AH lead acid battery I'd charge it at 100 milliamps for 12-14 hours. If you want to quick charge it, you could hit it with 500 milliamps for two and half hours.
Trips
Trips is offline
Old 03-07-2002, 09:32 AM
thanks..
RCdave is offline
Old 03-07-2002, 10:25 AM
thanks..
A also hear that too many quick charges will reduce battery life?
True or False?
Mr MTX is offline
Old 03-07-2002, 03:59 PM
I thought that its was overcharging that shortened battery life
RCdave is offline
Old 03-07-2002, 04:04 PM
RCdave is offline
Old 03-08-2002, 12:56 PM
Oh. by the way, im gonna use this battery to power a 12v starter to start my helicopter engine, does that have anything to do with the charge time?
RCdave is offline
Old 03-08-2002, 05:53 PM
ah oh...just gound out that this battery cant turn my engine. Looks like im gonna have to use a car battery
RCdave is offline
