Go Back  R/C Tech Forums > General Forums > Rookie Zone
Re-using rims >
Re-using rims
Re-using rims
Old 10-05-2009, 01:12 PM
veghead211's Avatar
Default Re-using rims
I was wondering if anyone re-uses their rims after the tires have become to worn to use anymore. If so, I also wanted to know if there is an easy way to remove the tires from the rims.
veghead211 is offline
Old 10-05-2009, 04:14 PM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Search the off-road forum, there are a bunch of threads on this topic
racer1812 is offline
Old 10-06-2009, 01:14 AM
88NATE's Avatar
Use acetone and some one told once to boil them [haven't tryed it yet]
88NATE is offline
Old 10-06-2009, 03:02 PM
I have removed some 8th scale tires by boiling it does work I have not remounted and check any yet to see if they are straight.
Mr GoodCat is offline
Old 10-06-2009, 03:37 PM
This takes time but works. Take a 5g bucket, put a brick or somthing in the bottom to set the wheel on. Pour acetone in the bucket so it comes up 1/2 way up the brick. Put wheel/tire in there and seal for a day. Check it after then and see how it's going. May take a little longer but this works, does not warp the wheel and leaves a clean bead on the wheel.
Astro is offline
Old 10-07-2009, 12:48 AM
Trader Rating: 19 (100%+)
I just pull the tyre back as much as I can and carefully cut it away from the rim with a razor blade.
I have done this a few times now and have managed to re-use both rims and tyres.
Shimmy is offline
Old 10-07-2009, 05:33 PM
Super Moderator
racer1812's Avatar
If you can do this they're not glued very well at all.
Old 10-07-2009, 08:27 PM
Trader Rating: 12 (93%+)
What he said. Have tryed this by pulling. No way you can if there glued correct.
killatoyota4569 is offline
Old 10-07-2009, 10:28 PM
JeromeK99's Avatar
i haven't bought new rims in over a year of racing!
I cut the old tires off with scissors.. leaving just a band around the rim on each side. Take the foam insert off... wash the rims.. then soak them for a couple of days in a sealed 1gal paint can in acetone. After a couple of days, all i have to do is peel off the bands and wash the rims again. I can usually get 5 or more sets of tires off a rim before it starts looking a bit to ugly or gets warped/damaged from running.
This reminds me I need to soak a few sets tonight!
Jerome
JeromeK99 is offline
Old 10-07-2009, 10:40 PM
Trader Rating: 49 (95%+)
Take a cookie sheet put some foil on it, pre heat oven to 350, make sure wife is gone, 12 minutes for tenth scale, 16 min for 1/8, wear gloves but tires will pull straight off of rims with all the glue and you are left with good wheels.
loopedout is offline
Old 10-08-2009, 09:54 AM
Glued good enough, got a set of masher 2ks and gladiators here that I have done it to, had quite a few runs on the mashers and have only needed to re-glue one small section on one wheel, gladiators have only had a few runs but are still fine.
I admit, I could put more glue on them, but I don't think I need to.
If I was racing then I would consider gluing them more just for the extra security, but I haven't really had a problem with them bashing.
Shimmy is offline
Old 10-08-2009, 10:38 AM
Trader Rating: 21 (100%+)
Make sure wife is going to be long enough for the stink to disappear!!
Duster_360 is offline
Old 10-08-2009, 03:36 PM
Trader Rating: 24 (100%+)
Throw em away !!!1 Not worth the effort.
tmaxxdaddy1 is offline
Old 10-08-2009, 09:55 PM
R/C Tech Elite Member
Trader Rating: 520 (100%+)
The Oven Method works for me, and is probably the fastest way to get your wheels back, but it does make a stink..
flame56mx is offline
Old 10-09-2009, 04:30 AM
Timbulb's Avatar
Spoken like a person who has too much money.
Timbulb is offline
