Go Back  R/C Tech Forums > General Forums > Rookie Zone
Fast, Faster, Fastest >
Old 06-07-2009, 05:38 PM
Default Fast, Faster, Fastest
Hey everybody,
just got into racing 3 weeks ago. Before that I've been around R/C since Tamyia had the original Frog out but just as a basher. I got into VTA with a used TC4 running a 17.5 on an LRP SPX Competition Stock with a 4 cell NiMh. I've asked battery questions before. The ESC is currently set at about midpoint aggressiveness (gotta play w/ it to see if more aggressive is better at the track). BTW, my gearing is at the high end of the VTA specs for my combo.
Today I'm looking for driving tips either from you, a link, or a thread here (so much info here). I'm looking to close a 2 second gap between the A main and the B that I'm in. I've place 1, 2, and 3 in my three races. I know the shortest path around the course is a tight one. But I'm looking for best ways to take turns both w/ steering and throttle control. And when the tight lines aren't the best.
I know I have to get in practice to get faster but I should practice the right way to get the best improvement right?
So, anything you got: links to helpful articles, threads in this site, even downloads. Just too much stuff out there and I know you folks know where the best stuff is.
Thanks for the help.
Tiger72 is offline
Old 06-07-2009, 06:01 PM
Trader Rating: 23 (100%+)
find what people are geared at for fdr's on the 17.5s and work on that. although the tc4 isnt the best racer on the track it is still competitive. ask yourself is you have enough traction with the vta tires. on the straits go high and then low on the turns or increase corner speed. how big is the track. i am geared at a 3.5 fdr and i am very fast on accel even with people geared at 3.7's and 3.6's. maybe a oneway will work, but see what other people are using. what surface are you running on?
not home is offline
Old 06-07-2009, 06:15 PM
Default answers to prev question
Surface - carpet
Other 17.5's FDR is 3.5 and 3.6
Track size - pretty big maybe 30 x 60 (bad at estimating the size)
I will take a closer look at what other guys are running. I think everyone in the A main is running 21.5 w/ 2c lipo as spec'ed for the third combo option. Can't afford that right now so I want to improve everything else I can now.
Tiger72 is offline
Old 06-08-2009, 05:00 AM
cyclone x's Avatar
Originally Posted by Tiger72 View Post
Surface - carpet
its all setup i won a big race with a 17.5
cyclone x is offline
Old 06-08-2009, 11:29 AM
Thirtybird's Avatar
The track is 100' x 36' high traction carpet.
I think you're losing a lot of time in the turns because it turns so much - those blue springs in the rear may be too stiff. With your motor coming off as such low temps, you may need to gear higher if you can fit it in. BUT, base that on what happens when you use that newer 4200 pack instead of the 3300's - those 3300's may not be capable of dumping the amps needed to really use that motor.
Thirtybird is offline
Old 06-08-2009, 03:23 PM
Thanks, I'll try softer springs and see how the newer battery affects the car. I do have another pinion to gear up that will fit. After that I'm buying a spur.
Guess I was off a bit on the track size huh?
Tiger72 is offline
Old 06-08-2009, 03:52 PM
Foxxrocket's Avatar
That's one of the most important things. And remembering that slow is fast.
It sound stupid, I know. But you have to experience it to know it's meaning.
Foxxrocket is offline
Old 06-08-2009, 06:35 PM
cyclone x's Avatar
yeha i understand
Old 06-11-2009, 07:02 AM
Well, raced yesterday. I bumped up the aggressiveness on the ESC by 1, used a 4200 batt instead of the 3300, and got help from fellow racers and a set up board for the first time. I shaved 1.1 sec off my lap time, picked up 2 laps, and won the B main. The set up helped tremendously. I never knew it could have so much affect on the car.
Still open to more tips if you got anything you want to share.
Tiger72 is offline
Old 06-11-2009, 04:32 PM
cyclone x's Avatar
what car r u racing with
Old 06-11-2009, 05:06 PM
A TC4 in a VTA class. The other components are in the first posting, I must have forgot to mention the car. Sorry.
Tiger72 is offline
