Go Back  R/C Tech Forums > General Forums > Rookie Zone
How to tap a motor screw hole >
Old 04-23-2009, 02:01 AM
5zigen's Avatar
Default How to tap a motor screw hole
So I just found out my CC Monster 2650kv motor has a 3mm screw hole and my Losi 8ight mounting screw is a 4mm. I want to retap the motor, but I've never done this before. Can anyone tell me how to retap the motor screw hole from 3mm to 4mm?
1. what do I need and where can I buy it?
2. How do I do it?
Thanks!
5zigen is offline
Old 04-23-2009, 05:00 AM
Trader Rating: 21 (100%+)
Is there no way you can use the 3mm screws and a washer or is the mount hole so big you can't make that work? The tapping process is going to generate metal chips and I wouldn't want those anywhere near a motor.
To do this right, it will require drilling the correct size hole and then running the right tap in to create the threads. I'd consider replacing the mount before I'd re-tap the motor screw holes.
http://www3.towerhobbies.com/cgi-bin...?&I=LXE221&P=7
RCM sells a new motor mount, it doesn't say wjhat size, but I've seen no one mention this prob so I suspect it is setup for 3mm screws.
http://www.rc-monster.com/proddetail...osa9198&cat=22
Duster_360 is offline
Old 04-23-2009, 10:52 AM
5zigen's Avatar
Thanks Duster.
Tapping the hole seems like PITA. I think I'm gonna try a 3x12FH screw with a washer and see how that works.
5zigen is offline
Old 04-23-2009, 05:38 PM
Not only is it a PIA, but can easily screw it up and wind up with a oversized, crooked hole that can't take any torque. You are so much better off solving issue some other way!
