Go Back  R/C Tech Forums > General Forums > Rookie Zone
ARC, DR, EPA, SubTrim????? >
Old 12-10-2003, 10:19 AM
twopie24's Avatar
Default ARC, DR, EPA, SubTrim?????
what does this all mean??? im talking about: epa, dual rate, sub trim, and arc. i just bought an airtronics mxs and im want to set it up, but before i do that i want to understand what they all mean and do as far performance and adjustability....and i did read the manual and it just showed me how to make the adjustments, it wasnt quite enough info....
thanks in advance for the help!!!
moses
twopie24 is offline
Old 12-10-2003, 03:51 PM
Smoke21's Avatar
Location: Pacifica, California OR Clearlake Oaks, California
ok Ill break it down I have this radio and the Instructions are crap for telling you what it does
Arc:(this comes from BuddaTech...)In Aritronics speak, ARC is an exponential adjustment. It stands for Adjustable Rate Control. A negative value will result in a less than linear control of the function. In other words...the servo (or ESC) will respond less qiuckly than either a linear (direct relationship) or positive setting.
Example:
For a nitro car you could dial in some negative to make the initial thorotle response less imediate. This may be useful if there is limited traction or the thorotle responds too quickly. The same can be done to the steering.
Dual Rate: Dual rate allows you to change the radius of your turn. In techical tracks you might want a high setting for sharp turns and on wide tracks you can use less steering to prevent oversteer
Sub Trim: centers the servo basicly it moves the range of movement left or right it is hard to explain (what I do for this is I accally set it to 0 then install the servo and then install the horn at center and make adjustments from there.)
EPA: END POINT ADJUSTMENT this allows you to change where the servo motion stops especially helpful for nitro engines as you don't want it to over extend the throttle arm
Smoke21 is offline
Old 12-10-2003, 03:54 PM
twopie24's Avatar
Talking
thank you very much..that is very helpful!!!
much appreciated!!
twopie24 is offline
