hi newbie here
hi newbie here
hi my name is eric and im new to this site.i have a few questions to ask,first,im wanting to build a rc car powered by a chainsaw motor.needing to know what parts i would need to build it.i have a complete electric traxxas stampede parts truck to use if possible.thanks for the help.
can anyone else help.
You are in uncharted territory as very few do this kind of build. You will have to fabricate your own motor mount for starters, you won't find one off the shelf. You'd be a little better off if you want a motor that big in going with a 23cc Zenoah like the HPI Baja's use - then you can use some of their parts. You're going to have major probs with power train - clutch, drive axles, trans, slipper, and diffs using parts from anything less than 1/5th scale and that may not be sturdy enough. Good luck
Hi eric, good luck with your project. Sounds crazy
I think you should start with a kit. Build it, run it, then repair it and get some experience that way. Im sure that if you really want to build your own rc car, you can, but is not going to be very fun for a newb. Good Luck.
You gotta learn to walk before you run......
Yea i wouldnt do it . Your going to have to go to a maching shop and get lots of stuff built. NOT A GOOD IDEA.
______________
mbx5r ace 1015
novarossi p7
eb mod
______________
mbx5r ace 1015
novarossi p7
eb mod
