Differential oil/lube
Hello to everyone. I'm quite new to the world of RC and am wondering what oil weight to run in the diffs. on my hotbodies lightning stadium? I bought it used and would like to check everything over B4 I run it. The engine does run, I changed out the servos w/ some heavy duty ones right away. It has seen better days but I think it will live. Please help.
Thank you!!!! Is it a rather involved process to change the gear oil?
Yeah they should have a parts explosion on thier website. It really isnt that difficult, I have a photographic memory so that aids me a lot. I'd say do one at a time so you dont forget what parts are for wich diff.
Run heavier weight diff lube if you plan to bash with it.
We used to have a lightning stadium truck, and unlike the buggy it worked best with heavy oils, 15-20-10 I believe, which was lighter even than the previous owner (LHS owner) ran in it. It had to be driven like a drifter to carry any corner speed since the heavy oil was needed to keep the diffs from unloading. Fun and predictable to drive, but too heavy to be really competitive racing IMO.
When you change differential oil do you need to clean it out good or just dump out the old and put in the new?
