Go Back  R/C Tech Forums > General Forums > Rookie Zone
Trakpower or Orion >
Trakpower or Orion
Trakpower or Orion
Old 02-03-2009, 02:12 PM
sp8y's Avatar
Default Trakpower or Orion
Hi all, Iím needing some new cells and Iím wanting to go lipo but canít decide between the Trakpower 3600 or the Orion 3800 what do people think is best also does any one know how thick the Orionís are as Iím going towards the Trakpower because I know that they will fit in my car (Serpent S400) with slight dremelling.
Thanks, Joe.
sp8y is offline
Old 02-03-2009, 02:51 PM
Ivan Dickson's Avatar
Trader Rating: 16 (90%+)
Thumbs up
Originally Posted by sp8y View Post
Hi all, I’m needing some new cells and I’m wanting to go lipo but can’t decide between the Trakpower 3600 or the Orion 3800 what do people think is best also does any one know how thick the Orion’s are as I’m going towards the Trakpower because I know that they will fit in my car (Serpent S400) with slight dremelling.
Thanks, Joe.
To me orion is the way yo go 3800 gives you more run time than 3600, I never heard of trakpower, I've used orion for years they have great products...
Ivan Dickson is offline
Old 02-03-2009, 05:37 PM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Both are quality packs...Trakpower has been around a long time. 3800 vs. 3600 you won't really notice a difference in run time it's only 200mah
racer1812 is offline
Old 02-03-2009, 06:30 PM
Trader Rating: 21 (100%+)
^^^ Ditto, both are high quality pacs. The Orion 3800 is listed as 136mm L x 47mm W x 22mm (0.87") height or thickness. 3600 Trakpower shows 20.8mm for thickness,so the Orion is slightly thicker.
Either would be a good choise.
Duster_360 is offline
Old 02-03-2009, 06:35 PM
LIVipers's Avatar
Trader Rating: 52 (100%+)
The orion packs are simply the best imo.
LIVipers is offline
Old 02-03-2009, 11:26 PM
gweed's Avatar
go with the smc 5200 24c or 500 30c either way they are better then those two
gweed is offline
Old 02-04-2009, 08:58 AM
sp8y's Avatar
Thanks for the replies, the Orion might be a bit tall so I think I might go for the Trakpower but havenít decided yet.
sp8y is offline
