Go Back  R/C Tech Forums > General Forums > Rookie Zone
New guy needs help with charger >
Old 02-02-2009, 06:21 AM
tiko's Avatar
Trader Rating: 35 (100%+)
Angry New guy needs help with charger
MRC Super Brain 989
Hi guys I need some help with this charger. I have been trying to set it up for a 4500 NiMh battery and the darn thing wonít charge completely. I think that I donít have the correct settings I have tried four different batteries and I get same result with all of them. Below I have the link for the USERíS MANUAL and what settings I have for Charging and Discharging. I would really appreciate any and all help that I could get from anyone and thanks in advance for your help.
http://www.modelrectifier.com/resour...989_manual.pdf
Note: A cycle includes both a discharge and a charge.
Note: 1,000 mAhís equals 1 Amp. Example: 3300mAh is 3.3 amps and 640mAhís is 0.6 amps.
You can use this formula to determine (approximate) charge/discharge
times for a battery pack in good condition
Capacity ų Amperage = Time
Example: 3000 mAh ų 1500 (Amps) = 2 hours.
If the capacity is lower than the amperage then multiply the result by 60 and that will give you time in minutes. Example: 3000 mAh ų 6000
(Amps) = 0.5 x 60 = 30 minutes.
Charging
Type: NiMh
Cell: 6
mAh: 4500
Amp: 4.50
Cut off Peak: 5mV
Temp cut off: 140F
Trickle Amp: 0.10
Discharging
Type: NiMh
Cell: 6
mAh: 4500
Amp: 2.00
Cut off: 0.90
tiko is offline
Old 02-02-2009, 06:31 AM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
How many mah does it put in?? What is the temp when it is done? How far down do you run it before charging? Discharge it to 5.4v (6-cell)and go from there.Also I charge my nimh packs at more than 1C. I charge my 4200mah at 5.5 amps.
racer1812 is offline
Old 02-02-2009, 07:20 AM
whitrzac's Avatar
Trader Rating: 96 (100%+)
how do you know its not charging all the way??
turn it on to a charge only mode, instead of a cycle mode
whitrzac is offline
Old 02-02-2009, 09:21 AM
Suspended
RobbieT is offline
Old 02-02-2009, 10:23 AM
tiko's Avatar
Racer1812
It put in about 2700mah at the end of the charge. Temp was 110, basically with my discharge settings that I have I start the charger and let it do its thing and once it is done I start charging. Now you mentioned to discharge it at 5.4v (6-cell) can you explain that in more detail please also on the more than 1C what do you mean by that I know that all of this questions may sound dumb for someone that knows what theyíre doing but for a rookie itís hard. Thanks for your help I do appreciate it.
tiko is offline
Old 02-02-2009, 10:31 AM
tiko's Avatar
Whitrzac
I know itís not charging all the way by what I get from the charger display and the numbers that I get at the end of the charge. As for the mode I have tried both and I get the same result.
tiko is offline
Old 02-02-2009, 10:49 AM
RC Dad's Avatar
Trader Rating: 26 (100%+)
It doesn't sound wrong that it's 110 degrees when the delta peak cuts it off. It's an either-or (temp or delta peak), whichever peaks first. Up the delta to 6 and you might get closer to 140 degrees. I think 120 is hot enough.
Superbrains are notorious for false peaking when on AC power with high output. If you use the DC inputs from a battery or power source you'll have more reliable results. If you're using the AC cord, you'll need to turn down the amps you're charging at - try 3.5.
It's also possible that your 4500 mah packs are sub-par, especially if they're old or has been sitting idle for a couple months or more. Packs after storage typically need several cycles to come up to full capacity.
RC Dad is offline
Old 02-02-2009, 03:06 PM
whitrzac's Avatar
are they tenergy??
whitrzac is offline
Old 02-02-2009, 03:16 PM
Super Moderator
racer1812's Avatar
I'm sure someone can explain this better than me but basically 1C is equal to mah divded by 1000 equals 1C charge rate in amps.
example 4500mah/1000 = 4.5 amps, 4200 = 4.2amps, 3300 = 3.3 amps
The exact charge rate is much important with lipo packs than nimh
Old 02-02-2009, 04:56 PM
Super Moderator
You've already got it covered actually. The last line of charger settings in your first post: Cut off: 0.90 This is per cell, the discharge stops when the battery voltage reaches 0.9 volts per cell. Or 5.4V for a typical 6 cell pack.
0.9 volts per is probably the most common cut off voltage, but the amp draw is typically higher for cycling.
Suggestion: Check each cell's temperature at end of charge (and discharge). Is there a hot one compared to the others? Might indicate a weak cell.
Dave H is offline
Old 02-02-2009, 06:02 PM
Suspended
Racer1812
just because you have a 4500mah pack does not mean you're going to be able to get 4500 into them. unless you start out with a totally dead/fully discharged pack (which you aren't, and shouldn't be) the 2700mah reading is all your charger is allowing to be put into them before peaking -- kinda like on a real car when you have a half-empty 20 gallon tank, you're only going to be able to put 10 gallons or so into it.
does that make sense?
RobbieT is offline
Old 02-02-2009, 06:15 PM
Super Moderator
racer1812's Avatar
i have quality 4200 packs that when discharged to .9v/cell they will take up to 4200-4300 mah to reach full charge. On a side note the lower the charge rate the more mah you will put in before the battery peaks but it also lowers the packs out-put voltage slightly... Racers are more worried about this.
Old 02-02-2009, 08:21 PM
tiko's Avatar
are they tenergy??
yes they are
tiko is offline
Old 02-02-2009, 08:25 PM
tiko's Avatar
Suggestion: Check each cell's temperature at end of charge (and discharge). Is there a hot one compared to the others? Might indicate a weak cell.[/QUOTE]
Ok Dave I'll try that
tiko is offline
Old 02-02-2009, 08:31 PM
tiko's Avatar
Yes it does, but even if I drain the battery and try charging it afterward it still wonít charge fully
tiko is offline
