TC3 drifting parts/charger/wheels recomendations
so i finally picked up the car from a friend.
"TC3, HPI 350Z body, hard ABS drift tires, 27T motor, Tamiya Fwd/Rev ESC, Hitec HS 322HD Steering Servo, and Losi FM Radio gear, RPM rodends, trinity bumper, graphite battery strap, extra soft green springs. venom 1800 battery"
i need a charger, and maybe another battery or 2 for it.
i dont need Li-po, i would love it, but too much money if im not going to be racing it. its just for drifting mostly.
what batteries should I look into? something with a decent run time, but nothing insane..
and a charger?
I also really want alloy wheels for it. but im having trouble locating the right size. i dont know why, it seems like it would be easy. maybe im just not searching for the right things.
thank you!!
and a charger?
thank you!!
don't know why you'd want alloy wheels, except for my bling factor. but if you want some "drift" style wheels. check out what jeff has in stock at www.speedtechrc.com he carries tons of JDM ( ) wheels imported straight from speedwaypal japan. they make some awsome looking wheels and have awsome quality.. HPI also makes good wheels too, and their type T tires are great.
as for batteries, i'd probably either hit up cheapbatterypacks.com or something. for drifting, you'll get quite decent runtimes (35+ minutes) on let's say.. 3800mah+. drifting doesn't require much power, so even if you're on a budget, you can get good stuff without breakin' the bank. for a charger.. it'd would really depend, i'd probably go with the superbrain 960 if you don't need anything special. it's only $50. btw, change those plugs out to deans! haha.
