AMB transponder and Futaba FASST
Utterly simple question, but what do I plug my transponder into to power it up? Is there a LED light that indicates it's powered (I'm away from the vehicle currently)?
It's a 3 channel FASST receiver with a BEC plugin in addition to the 3 channels. I'm also using the Traxxas Slash stock speed control and motor. My guess is it plugs into the BEC, but I thought that's typically to power the receiver, not take power from it. Thanks in advance.
If you are using an electronic speed control (it powers the receiver), you can plug it into an open 3rd channel or the batt/bec spot. Just make sure you have the red(pos+) and black(neg-) in the correct spots to properly power the transponder.. the LED will light up when the car is turned on if it is hooked up correctly.
Have fun!
Jerome
Have fun!
Jerome
You plug your transponder into the 3rd channel slot, I use the fasst receivers also.
have fun
have fun
