lipo battery
lipo battery
can run a lipo battery without using brushless motor and esc.
Super Moderator
Trader Rating: 31 (100%+)
Simply put, yes. You might want a lipo low voltage cut-off though
lipo
can u give a good idea on a good battery and charger. and what is the cut off your talking about
Lipo batts are made from individual lipo cells. A 2S or 7.4v lipo is made with 2 separate cells. The minimum voltage for a lipo cell is 3volts. If you discharge a cell below the minimum voltage it can become damaged, the overdischarged cell can puff (swell). Now the cell is potentially dangerous to either charge or try to run and you've ruined the battery.
Novak smart stop is an external low voltage cutoff that interrupts the voltage when the voltage falls below a preset amount, like 6volts for a 2S lipo. I'm using one in an older 3906 Emaxx to protect the lipos from being overdischarged.
